Threads: 19
I too am that old to be using X10 ;-)
My understanding is you would need a dedicated UCM for Zwave, but you might want to consider the new Ucm/Pi.
I have bought some Figaro fgs-212 modules, which I hope to get set up next weekend. There are DIN mounts available for these. I am therefore intending to fit these into my DIN panels in place of the x10 modules. This has the advantage of not needing to change any of my switches, wiring, etc as they can be programmed to work with either on/off or momentary switches.
I can\'t help on the other things.
I have just added a Z wave stick to the Ucm/Pi I have.
This stick allows configuring the network, so no need for veraedge (I could be wrong here, but that is my understanding).
I would really suggest having a look at the Ucm/Pi if you don\'t already have the zwave UCM. This has opened up a huge amount of additional control (imo), such that I can now easily configure voice control, links with cctv, zwave, etc.
There are others on here who know far more about this than me, so hopefully they will respond to correct any mistakes I\'ve made.
Cheers,
John.
Threads: 868
1
Yes, your list should be correctYou need a Zwave controller to set up the network initially and to make changes ( I am not sure that we recomended vera edge as the preferred controller as I do not remember testing that, but any controller should work)
John is correct that the UCM/Pi should give you more options
UCM/Zwave is limited because it works only on the older series 3 Zwave modules eg Ok on lighting and appliance modules. Some of the new fibaro modules may not work so well with UCM/Zwave, as our development in the direction is limited
But if you just want to control appliance and lighting modules to replace X10 that UCM/Zwave should be no problem
Threads: 19
I\'m not an expert on this, I\'m following along in the wake of the others in the Beta testing group.
- The UCM/Pi comes with the Pi module plugged in, so you buy it as one. It has the program pre loaded.
- You plug the Z-wave stick into the UCM/Pi itself. The stick is an aeon labs z stick usb controller gen5. Have a look on vesternet.com
I bought mine from amazon for a similar price.
- You use Node-Red to configure the connectivity on the UCM/Pi, which includes the Z-Wave. If you already have flags or responses in your Comfort Config you can link straight to them.
One of the guys in the Beta group has shared node diagrams to show how it can be used to Add/Remove Z-wave nodes, Set/Get values, etc. You would presumably do this using the node red dashboard, not the comfort panel/app.
Its early days for me as I haven\'t received my Z-wave devices yet, but I am hoping I can configure my system without the need for any other master controller.
I should say, just how easy this would be to configure will depend on how techy you are. I am techy but there are still moments of head scratching and swearing ;-p
Development is ongoing so this is likely to get better with time.
Hope that helps.
Threads: 9
Hi John
Thanks for the info - sounds great, good luck with your trials. I am techy and never give up, so will follow the forum for pointers.
Would be great to hear how you get on
Mark
Threads: 32
Hi All,
I have use the Z-Wave UCM for a number of years now and it works great so long as the modules are supported most of my modules are 3+ years old. I have at least 15 z-wave items in my network but I have not managed to get the latest Fibaro Double Switch 2 5 Gen to work which I think Chiu has already mentioned.
Is there a plan to develop the z-wave UCM to work with new z-wave products? It has been a valuable asset to my security system. I have a lux sensor that triggers z-wave lights and appliances depending on external light levels (Vera lite is my main z-wave controller and its a great but obsolete unit...the z-wave ucm acts as a bridge. As well as the lux sensor I have PIR\'s triggering lights and depending on the alarm mode lights do different things.
LED strip lights simple use the 12v outputs and they works really well.
I have tried Danfoss z-wave rad valves and found them to be a little problematic and never manage to get them to work with cytech the way I have other z-wave items I believe this is because they are not bi-directional in nature plus they only check in every 10/20mins. I needed up using a schedule within Vera to change temp setting morning and evening e.g bedroom 20degrees morning, lounge 18 degrees during the day both to 18 degrees and then increasing them at night. However, end up changing them manually outside of the schedule.
I am now looking at something like a Honeywell Evohome to add heating zone control. Has Cytech integrated with any of these systems via the universal ucm? it feels like this is the way forward. The universal UCM works brilliantly with my Yamaha amp for example.
Finally what is the purpose of the ucm-pi? many things are coming with the Alexa app inbuilt but fundamentally this is not always the best solution for example.....Alexa turn on lights at 3am wake the whole house, triggering a PIR with a cytech rule sets the right light level for the time of day and doesn\'t wake everyone.
Lee
Threads: 868
1
We do not intend to extend the UCM/Zwave to work with the new Zwave products
The interaction of our type product with Zwave is complex and problems with setup and connection occur which are outside our control due to the range of the products are difficult to resolve (I think you had a similar problem earlier)
And we have not sold enough ucm/zwave to justify further development on this
The UCM/Pi is not just about alexa. You do not need alexa or smarthings - that was the original community version.
Threads: 32
Thanks for the feedback. Can I ask what is the best approach for dealing with lights/appliances moving forward? I don\'t want to invest more money in to z-wave modules if the are not going to work with comfort. Turning lights on and off is a key function of my system.
Threads: 868
1
CBus, and KNX are good alternatives.
Your current zwave modules would still contnue workiing.
Keep an eye on UCM/Pi as users are working on Zwave and Lightwave RF
