Yesterday I installed Comfigurator v3.12.8 and used that to update my Comfort firmware to v7.142. I immediately noticed that my Comfort controlled external lights were not functioning nominally. It turned out that ALL of my Comfort flags were set to ON - every single one of them, including all of the unused flags up to Flag254. So my response programming wasn\'t performed as expected because the expected state did not match reality.
After I manually (inside Comfigurator, under Comfort Registers/Flags) enabled Show Status, I was then able to set all of the flags that I use back to OFF. Things once again appeared nominal.
Now, I can code around this sort of scenario and reset them at opportune moments, but it\'s new behaviour that I\'ve not seen before with firmware updates that I\'ve applied.
Any thoughts? Did I do something wrong during the firmware update process and do I need to revise my procedures perhaps?
