KP04A Firmware 7.008 to 7.016
From Firmware 7.008, KP04A and KP06A are different, because KP04A has been extended to support the CM9001-EMS Environmental Monitoring System which has its won website https://www.cytech.biz/brochure/ems.html
KP04A is able to switch bto EMS Mode to view up to 4 sensors and their setpoints, and change the setpoints as well as enable or disable the setpoints.
KP04A can be set to Alarm Mode (normal) or EMS Mode
KP04A 7.008 (27 April 2018)
  • Supports EMS Mode for sensors and setpoints
KP04A 7.010 (6 Aug 2018)
  • Changed the behaviour of the F key. Pressing F key clears the alarm message on trhe LCD and shows the EMS mode ie Sensor values
  • The F key also behaves like in Alarm Mode, ie it ends the voice menu and is used for keypad shortcut keys 0 to 9 and *
see http://www.comfortforums.com/forum139/4912.html for KP04A functions in EMS Mode
KP04A/KP06A 7.016
  1. Removed requirement of having to press F0 and engineer code before entering menu mode by pressing and holding the * key. This simplifies the access to keypad menu mode
