Threads: 62
Seems a very strange announcement. Dial tone is what you hear when you pickup the handset and can either be locally generated or generated by the ITSP. If it\'s completely off then there is no way to determine if the phone is dead or just not playing any tones. Going fibre should have no effect on the user experience.
Threads: 885
Perhaps they mean that the telephone network will be using fibre optic cables to every home?
Threads: 64
Even VoIP lines provide a dial tone, I find it hard to see why andial tine would he removed in Any event?
Threads: 885
Our experience is that there may be problems dialing out on digital lines with analog phone adaptors. Not so much for Voice, but if dialing to Central Monitoring Stations (Alarm receivers) due to the latency and delays in the digital networks.
The UCM/GSM4 (3G) performs better for dial to CMS.
In any case if they really remove the wired land lines, the GSM module is a good aletrnative and not very expensive. And in many new homes, there may not be a land line
