Threads: 25
Hi.
Can ISM06/ISM07 when given 240v input set flags or counters?
If so how is done?
Threads: 880
05-18-2018, 03:16 AM
(This post was last modified: 06-18-2020, 06:38 AM by slychiu.)
ISM06 and ISM07 is able to switch 240V as the relays are rated for 240VHowever they should not be used to switch 240V as it may not bbe sufficently speratwed from the low voltages on the IRIO
Please use IRIO-IO and RLE02 for mains switching
