Comfigurator 3.12.1
Bugs Fixed from 3.11.4
New Features
Comfigurator 3.12.2
Known Issues
UCM/Cbus2
- Home Control Menu in some view modes did not work
- Graph References caused exception if a printer is not set up
- Fixed bugs in View modes
- IRIO when IR Signal Output was mapped to Counter and changed to Flag, an exception occured
- In Modbus, if Display mode is Decimal when the file is opened, when you go to the Modbus to comfort, the display is hexadecimal. To show as decimal, you must change the mode to hexadecimal and back to Decimal, then the display is in Decimal.
New Features
- Re-origanised the display of screens in Comfigurator categories to make it easier to access http://www.comfortforums.com/forum20/4763.html
- View Mode: Automation has been added to other view modes (User, Simplified Engineer, Advanced Engineer, EMS). The view mode is now saved in the cclx file. Each default template has a default view mode. see http://www.comfortforums.com/forum20/4763.html
- Added Multi-Convert actions (Action code 159) - Convert deg F to C, Deg C to F, Convert (0-99) to (0-255), Convert (0-255) to (0-99). From Firmware 7.128. http://www.comfortforums.com/forum20/4765.html
- Added Action Code Toggle Counter (action) 158. This treats the counter as a binary object. If the counter value is 0, it becomes 255. If the counter value is >0, it becomes 0. From firmware 7.100
- KP04A/KP06A Properties - Tamper is disabled by default. Most users disable Tamper so default disable is more convenient
- Status of Flags, Counters, Outputs can be set, cleared or value changed (for counters) http://www.comfortforums.com/forum20/4764.html
Comfigurator 3.12.2
Known Issues
- UCM/EHG - ehome to Comfort cannot select Comfort registers - pulldown menu is blank
- Vocabulary Upgrade error - For some systems Vocab u[pgrade stops at 23%, 50% and comfort is reset. Do not attempt Vocab upgrade at this time
- In View Modes; Automation and EMS, the Control Menu status checkbox is shown, but the actual status is not displayed
UCM/Cbus2
- For Learn mode and Monitor mode, the sent and receive messages to Cbus ae shown (instead of just received messages). The sent and received message are converted to ASCII for display
- Time programs screen has number for Time programs. Time program number ie 1 to 32 is displayed so that when programming, users can relate to the number
- If you open a cclx file which is different Comfort eg Open Comfort 2 Optimum but connected to Comfort 2 Ultra, after Scan for modules, the wrong model was displayed. Now Comfigurator will show the actual scanned model regardless of the open cclx file
- Fixed bug - In View Modes; Automation and EMS, the zones status checkbox is missing
- Known Bug - in In View Modes; Automation and EMS, the Control Menu status checkbox is shown, but the actual status is not displayed
- Name of the Unused Bit 6 in Configuration flags change to to \"GSM Priority Dialout (Requires firmware 7.136) and above. This causes dial out by UCM/GSM4 as priority even when the phone line is connected. By default, system will dial by fixed phone line, and when phone line is down, will dial out by GSM
