02-08-2018, 02:40 PM
Hi,I was looking at the options here but didn\'t see any mention of leak detection. Has anyone implemented this and is it possible? Thanks
Leak Sensor?
02-08-2018, 02:48 PM
What do you mean by a leak, are you refering to a water detector?
02-08-2018, 02:56 PM
Yes! I\'m looking for a way to detect water leaks to complement the other sensors.
02-08-2018, 06:14 PM
I think Smart Things have a water leak sensor
There are also modular water leak detectors which use a special cable . These can give a dry contact when there is water
02-08-2018, 06:26 PM
Cheers! I\'ll check those out....
02-09-2018, 12:37 AM
You can get a basic water detector board which is a open circuit and attach it to a zone if water is present it will trigger any response that you set
02-09-2018, 02:35 PM
https://www.ebay.co.uk/itm/5-24V-DC-Wate...2221383166&hash=item2ef0fa49ba:g:hgAAAOSwonBaSG4B
This is a simple water detector I installed in sub floor level works well just connect to a zone!
02-09-2018, 03:12 PM
Cheers. I\'m sure someone somewhere put 240vac through it but that looks perfect for my use case (12v of course!).
02-09-2018, 04:10 PM
If your connecting directly to a comfort system this works, you can also get water sensors that are on a flat pcb board that do exactly the same thing.....
« Next Oldest | Next Newest »
