UCM/Cbus 2 Firmware 7.054 to 7.106
UCM/Cbus2 7.054
  1. Fixed Bug - Enable and Trigger Group addresses did not update the mapped Comfort Counters
  2. Fixed Bug - sending commands to Trigger and Enable groups by Response wizard did not update the mapped Counters
  3. Fixed Bug - changing counters in Comfort mapped to Enable group addresses did not send the change to the Enable group. Now this allows commands to be sent to an Enable group by changing the value in the mapped counter
UCM/Cbus2 7.068
  1. Sending Flag value mapped to cbus group address will take effect even if the flag state is not changed.
  2. Improved firmware upgrade so boot sector may not be updated if there is no change
  3. Improved firmware upgrade so it may work even if UCM/Cbus is reset during upgrade
  4. If counter change originates from ucm/cbus, comfort broadcast counter change will be ignored by ucm/cbus to avoid the endless feedback and change when slow dimming by cbus2. This improves slider on app
UCM/Cbus2  7.106
  1. Fixed occasional problem initial zone state transmitted to C-Bus Security application zone status may not be updated
  2. Improved Monitor Mode for cbus soo that messages  Received from Cbus and  Transmitted to Cbus are displayed. Previously, only message from Cbus are displayed. This requires Comfigurator 3.12.2 (not available yet)
  3. Work-around for rare problems for some C-Bus networks where the C-Bus serial interface was not able to receive a full status reply for the Lighting Application and hence was not able to initialise resulting in the ERROR led remaining on. Cbus2 firmware will not go into Smart Mode even if the Status Reply is not received from Cbus Lighting application
(12-16-2017, 01:41 PM)slychiu Wrote: UCM/Cbus2 7.054
UCM/Cbus2 7.068
UCM/Cbus2  7.106
I think this is all very mixed up !
- This page suggests that UCM/CBUS2 firmware is 7.106
- The Cytech web site firmware pages suggests 7.136
- When I load up a live CBUS module the page display says latest version is 7.214 but when i go to check for firmware upgrades it says 7.213 is the latest.
Clarification please !
The Comfigurator version is just an online text file that is referenced when doing a firmware check. Sometimes Cytech forgets to update this text file, it happens. The latest is always the one on the download server.
The old UCM/Cbus2 firmware is indeed 7.136. The ARM based UCM/Cbus2 is 7.214 as the download site suggests.
(09-29-2026, 05:59 PM)Ingo Wrote: The Comfigurator version is just an online text file that is referenced when doing a firmware check. Sometimes Cytech forgets to update this text file, it happens. The latest is always the one on the download server.
BUT 7.136 is ONLY available forma live Configurator scan for latest firmware update - It finds 7.214 but when you go to upload it gives an error - hence me going to the Cytech web site to see if I could download the firmware file.
