11-07-2017, 03:03 AM
Hi, I have a Comfort system installed and working with normal alarm sensors and single Heat&Smoke sensor centrally placed in the house. When I originally installed it I tested all the zones including using the test button on the fire sensor.
Fortunately the fire sensor has never triggered in a real situation so far. However, something occurred to me today... it is a 24 hour zone. So, what will happen if say we have a very smoky cooking session and the smoke manages to drift through the house to the sensor (very unlikely, but theoretically possible). The sensor will trigger a fire alarm. If we then \'cancel\' the alarm by entering a user code on the keypad, will Comfort continually re-trigger the fire alarm until the smoke eventually clears from the sensor?
The sensor is connected in non-latched \"auto reset\" mode and the docs say it resets when the smoke has gone. So, I assume the sensor will permanently stay in \'alarm\' mode until clear. Even in latch mode, that just tells it to say in \'alarm\' state until power is removed, so even then if the smoke is still present it would trigger again.
So, in addition to my question above - If Comfort would keep re-triggering, how can I avoid this - e.g. force it silent for a period, or something like that? I want to avoid the situation where I\'m at work and I receive a phone call from home telling me they can\'t silence the alarm because the overzealous cooking smoke hasn\'t yet cleared. That would NOT go down well.
Will I be able to set a flag when the fire zone triggers and then AFTER the user signs in and acknowledges it, maybe use a Timer for say 30 minutes to prevent that zone re-triggering, or is it impossible to disable fire zones in that way (as I vaguely recall reading somewhere in the docs)?
