Android app
The page (2) displaying the comfort zones.... all zones appear to display Ok on start up.
HOWEVER the page never appears to refresh. So basically you are left with a time slot of the zone status.
Surely this can be made to be an ACTIVE page.
This is the 1st generation android app? Not the 2nd generation?>
It MUST be the second generation we are using!
NOT attempted to use any apps until ( as I thought) all the bugs were ironed out ! - so first real usage only started back in July Aug.
Quote:It MUST be the second generation we are using!
You posted this in the \"Android apps 1st generation\" subforum so I need to make sure you are using the G2 app.
I have moved this to the normal Comfort android app forum
The zones should definately change in the app when the actual zones state changes
Make sure your Comfort and UCM are upgraded to the latest firmware and you are using UCM/ETH03 also with ETH03 upgraded to the latest 2.23, see http://www.comfortforums.com/forum113/3904.html
The firmware is probably the reason why you have the problem
Zones are working for me in Android.
Quote:NOT attempted to use any apps until ( as I thought) all the bugs were ironed out ! - so first real usage only started back in July Aug.
Your feedback and requests are noted.
If you used earlier, you could have given your feedback earlier when other changes were being made, which would have been very useful.
I Use both 1st & 2nd gen Android Apps and have no issues with either displaying zones active/inactive can get laggy but the likelihood is down to the internet connection on both lan and wan.
I think firmware version is more likely
UCM is 7.098 BUT of course i cannot access the UCM itself remotely so will have to wait until next physical visit - pretty sure it wont be 2.23
