08-28-2017, 11:42 PM
Hi all,
I am using KNX2 firmware 7.097 and I have now implemented a \"Bypass\" feature in my KNX visualisation: Group addresses are mapped with register type \"Bypass Zone\" to individual zones. This works fine so far.
The surprising thing is that this while bypassing from a keypad needs a sign in the KNX bypass telegram works without any prior sign-in, regardless of the arming status and even in Away mode. This means a possible intruder could actually disable the alarm system without any signing in by accessing the KNX bus and sending to the correct group adresses.
Is there any way to make Comfort require a sign-in for a KNX bypass, similar to the \"Need Code\" setting for the keypad?
Thanks,Stefan
Thanks,Stefan
