Threads: 1
The three keypads in our home started to warn against a low battery recently (AC LED blinking red and audible warning) and knowing next to nothing about this installation I luckily came across this forum.So basically I removed the 12V 7AH battery (been in there for around 4-5 years) and replaced with a new one today. The system seems a little happier but the Home LED is blinking green and I am not sure if I have to do something to return it to the normal green steady status.Any help on this would be much appreciated.If you need more info on the system I will try and upload some images if needed.
Thanks in advance
djj
Threads: 62
Try pressing the following on the keypad: F then 3 and finally 1. This initiates a battery check.
Threads: 885
New batteryies may not be fully charged.
The 1st time you do the battery test it may give Battery warning but when it is charged then there should be no battery warning
By the way the battery test is done automatically every 24 hours from the kast time you do a batery test
Threads: 885
If the battery is low, F31 willl report Battery Warning, followed by Battery Restore (as the test ends)
if the battery is good, there is no announcementy
Threads: 885
The LCD should report thr trouble which caused the green led to blink
If you have not signed in to your keypad since the batery warning then the greem will still blink because you have not acknowledged
Sign in with your code on the keypad to acknowledge and check if the green is still blinking
Threads: 885
Steady red AC LED means there is Power faillure
