Force Arm
I have a Comfort II and am doing some reconfiguration.I want to Force Arm (arm the system with open zones) using a response. I have had this working in the past but not at the moment.I am using the response ForceArm, the underlying codes being 17, 255I have \'Allow Force Arm\' ticked as Yes in Security Configuration Flags.If I execute the response nothing happens.The I/o monitor shows;>
LI****
< LU01
> DT
< DT2016112900313300
> EL
< EL11FFFFFFFFFF
> f?00
> Y?
> Z?
> z?
> M?
> K?
> a?
> DA11FF
< f?000100000000000000000000000000000000000000000000000000000000000000
< Y?0000
< Z?250000
< z?000000000000000000000000000000
< M?0001
< KL00010000
< a?000000000000000000
< RA0000
Any suggestions as to why this isn\'t working?
Action 17 is Force arm if arming
in Security > \"Force arm if Arming\" in the screenshot below
This means that the sytem will Force arm only when in the process of arming, it does not force arm the system if it is not arming
This is what the # key on the keypad does - it causes Force arm only when the system is tryin g to arm, it does not work that way when system is not arming
I must have been using Auto Arm Away. Thanks for your guidance.
