"UCM located further..."
[size=\"3\"]Q1/.
On reading the instructions for my newly acquired UCM/USB:
Page 5 of ucmman state \"...up to 100 meters, use a cable with 3 twisted pairs. 12V/GND, KA/KB are to be paired with one pair as spare\"
I\'d like to confirm how these connections should be made.
As I read it (admittedly late at night Sad)[/size]
  1. [size=\"3\"]12V&KA are linked - at both ends?
    [/size]
  2. [size=\"3\"]GND&KB are linked - at both ends?
    and the third pair are
    [/size]
  3. [size=\"3\"]A & B which are connected respectively at each end
    [/size]
[size=\"3\"]Somehow I feel this isn\'t right and I\'d prefer to ask dim newbie question rather than \'fry\' something!
Is there a pic\' somewhere that will help me.
Q2/.
Is there any reason why I cannot have RJ45 plugs and sockets in the line, this will allow me to extend a redundant cat5e cable already under the floor which at the moment does not quite reach.
The total run between the UCM and Comfort will be no more than 8 meters.
Thank you
[/size]
12V and GND should be paired and KA/KB should be paired, and connected at both ends
the spare pair need not be connected
There should be no problem in using RJ45 plugs and sockets
If your UCM/USB is extended to 8 meters to connect to your computer, it may be more convenient to use UCM/ETH03 conencted to your network so your computer with wifi esepcailly a laptop can access from anywhere. If you have a fixed desktop, then USB may be better
