Hi, I have some contractors working and I want to bypass 3 garage doors and a PIR, I thought that the response attached would work but it only bypasses the first device.
Any help appreciated.
Try Executing the Response directly from Comfigurator in the Response menu
Do a Security Check on the keypad F3,2 to hear the announcements of open zones
Then Open the zones and move in the PIR area. When bypassed the zones should not be announced in Security Check
Execute the Unbypass Response and do the security check again if you have exited the security check mode. Now the zones should be announced when opened
If you are testing the time program by changing the time note that you have to set the time before the programmed time, eg 1 minute vefore. You cannot change the time to after the programmed time otherwise the Response will not be executed
There seems to be a problem with the Execute Response for Bypass zones
You are correct that only the 1st zone is bypassed
The same with execute response of Unbypass zones
However if the response is excecuted by the system eg by Time programs then it works so I believe tit will work in Time programs
You can also use the Do Response command R!NN where NN is the Response number in hex. This wil work becvause it is doung the response instead of the individula actions via DA...
We will check why this bypass actions in sequence do not work
Hi, I have noticed that even though the bypass is set from 07:30 until 19:00, if I return home and disarm, then go out and rearm; the bypassed zones have been unbypassed.Is this supposed to happen and if so how can I force the bypass to remain operational until the end time is reached?
