- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
UCM/Log and LGX01 Firmware 7.123 to 7.189
Threads: 885
04-12-2017, 08:39 AM
(This post was last modified: 04-12-2017, 08:39 AM by slychiu.)
Changes
- Detect LEM or LEM03 connected for main Controller and slave
- Fixed Bug Scan for Modules via plug in ETH03 (Or USB for UCM/Logic) gave wrong modules if a UCM at ID 1 is not present.
Threads: 885
UCM/Logic and LGX01 Firmware 7.153- Fixed BUG CM command counter value 0 to 9 did not work for Cytech App
- Control menu is authorised for engineer code
- Control menu - control feedback for Counters dont change value incoming 1 to 255 (was used to support certian external ucms)
- Improved support for ETH03 plug in
Threads: 885
UCM/Logic 7.169- The Counter Response is also activated when UCM/Logic changes a Counter value. Eg by Responses/ Action codes or Control menu. Previously, Counter Response is avtivated only when the counter us changed by a UCM
- No of Responses number from 1024 to 512 affect ucm/log, knx/logic
- Removed x10 responses not used affect knx/logic and ucm/logic
- For plug in eth03 for LGX, UCM/LOG, CM9001, Sensor, Counter, Flag command will echo state eg C! Will report CT
- enabled extended Sensors function
- Fix Bug counter report ââ¬â if counter reponse changes another counter, the counter report for the changed counter has the same conterid as the original. So if KNX send counter, counter response change another counter and the counter is reported to knx, the counter id remaiins as KNX ucm id so the KNX ignores the new counter report
Threads: 885
UCM/Logic 7.189- Fixed Bug Action 158 clear and set counter did not work, but toggle worked
- RIO Inputs and Outputs is supported
