Upgrade of old system from 2011
I have a Comfort Ultra II (gen 2) system that I purchased in April 2011 (plus 2x LEMs, and 1 SEP). For various reasons it got bench tested and then never installed. I\'m finally resurrecting my plans again and will be unboxing and installing it soon.
From a quick skim of the firmware updates page it seems things have moved on a lot. I believe my firmware is v5.x and I understand from the upgrade instructions that I will need to use a cable-based UCM to upgrade my firmware and then I can use a UCM/ETH03 after that.
Can anyone answer a couple of simple questions for me:
1) I don\'t yet have a UCM/ETH03 - if I buy a new one, will the \"UCM\" part of it let me do the initial firmware upgrade that means I can then use the ETH03 part for future updates, or do I have to buy a basic cable-based UCM?
2) Have there been any other mandatory hardware updates in the last 6 years that would prevent me from simply upgrading to the latest 7.x firmware for the main Comfort system?
Thanks.
Yes, much has changed in 6 years
Comfort Firmware version >5.00 must be upgraded by UCM [programming cable
But if the firmware is < 5.100 then you first need to buy a MpU01 Plug in Module to replace the processor with a flash-based type. The MPU01 will have the latest v7 firmware so you do not need to upgrade the firmware, and can use Comfigurator and the UCM to upgrade in future
see info at  http://www.comfortforums.com/forum4/1783.html
The new UCM/ETH03 will have the UCM firmware upgrading cable
The Comfort 2 hardware will still be compatible with the new systems, although there may be minor improvements
Hi, thanks for the info.
My main Comfort system appears to be v5.206 firmware but the MPU01 module (I assume that\'s the extra add-on bit in my attached photo) looks different to other MPU01s that I\'ve seen for sale. Can my module definitely be upgraded through a UCM/ETH03?
Just to be clear, I assume the cable that you said would come with a new ETH03 will definitely allow me to upgrade my old 5.206 firmware? I\'m sure I saw elsewhere that the ETH03 will only with v7.xx firmware - I won\'t be in a chicken & egg situation, will I?
Also, can you confirm that I can connect both an ETH03 and a GSM4 module at the same time?
The plug in module in the photo is OP01 the Output module, not MPU01
Your comfort 2 is not the old one that comes with MPU01 sockets because the CPU is a flash processor that can be upgraded
However firmware  5.206 needs to be upgraded using the UCM firmware upgrading cable. The UCM/ETH03 or UCM/USB comes with the cable that can be used to upgrade the firmware to version 7
Comfort allows 8 ucms to be connected  so UCM/ETH03 and UCM/GSM both can be commected
I\'m hoping someone can advise as I\'m getting very frustrated here...
So, my ETH03 arrived. I\'ve connected it up as per the instructions for doing an old 5.xxx cable upgrade (my current main Comfort Ultra firmware is 5.206):
ETH03 is connected to local LAN.
IP address is static
Comfigurator (v3.11.12.0) is talking to ETH03 - CS Manager can see it and Comfigurator comms method changed and IP set and it shows in toolbar (and proved if I unplug Ethernet cable that it says there is an error)
UCM is connected to Comfort using standard 4 way cable AND the programming cable (6 wire header at comfort end, the other two wire and 6 way 4wire version at the UCM/ETH03 end). PP2 is shunted (although there is one jumper labelled PP2 below it and PP1 above it - I assume this is the correct one to shunt)
Green RDY light is lit on UCM. Red power  and Green Status both lit on daughter ETH03
NOTHING lit on Comfort mainboard (is that normal?)
[color=\"#ff0000\"]Yes that is normal - Cytech support[/color]
Keypad is beeping constantly about twice per second (VERY annoying after an hour of this)
[color=\"#ff0000\"]Yes keypad will beep because Comfort is not operational in this mode so keypad is not polled. Once the programming cable is disconnected and Comfort is reset, the beeping will stop
[/color]
In Comfigurator, selecting upgrade Firmware by UCM cable lets me choose the file 7.116 that I downloaded (I tried 7.032 too). It then asks for confirmation, then almost immediately says \"UCM does not support this operation\", then the Busy1 red LED on the UCM lights up and stays on.
Same happens if I try again whether or not I press reset on UCM.
[color=\"#ff0000\"]When you see an error message and Scan for Modules Yews/No. Enter NO. Do Not scan for modules again as thet will not work, and will cause the error to be repeated
Justy performa the upgrade operation again
[/color]
I also just tried powering up without the UCM Upgrade cable connected. I believe this shouldn\'t work anyway as my main firmware is too old to work with the UCM/ETH03? Anyway, it doesn\'t seem to do anything when I try to do something like Get System Info, it asks for a user code (I\'ve tried default user code and engineer code, which work on keypad) and it then says it cannot connect to UCM.  The Keypad also says \"Phone Trouble. Controller\"  The Comfigurator UCM IO monitor shows:
> LT01
> LT01
> LT01
> UB0100FE
< NA
< NA
< NA
< UB01F0
< LU00
> LT01
> LT01
> LT01
> UB0100FE
< NA
< NA
< NA
< UB01F0
< RS11
> LI****
> LI****
> LI****
> LI****
[color=\"#ff0000\"]If you attempt the upgrade wuth initial error and you repeat the operation, the IO monitor will show this
> LI
< LU00
> LT01
> LT01
> LT01
> UB0100FA
< NA
< NA
< NA       Initial Error message
               Repeat the upgrade Operation
< UB01F0
> LT01
< NA
> LT01
< NA
> LT01
< NA
> UB0100FA
< UB01F0     This 2nd attempt succeeds
> UB02
< UB02
> UD03FEF0F0F3EBC9568D8CD0E5B4169BAF5059CCC3DAE41F05D3EAA67657E2F978BE715D9957E2F978BE715D9957E2F978BE715D991B6AA10BCBEA862E80FF0A1E1D385D91D2057DC51084E15AA2CDF9BE2B5626CDEC2DC2FDFB198FEEDFEF08735C7B6399C839A89E4C029640887B679296D0A7D42DEB6CF82BDAB28ED8B5F41C1B321ECCA4D852B02BD4A2EF97D879CCFE6AE8626257FF32CE4FE47D55CDF957909FA6104373F56EEBE8C1A38DC2A1AE2471AE3957E2F978BE715D9957E2F978BE715D99FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D
< OK
> UD000000F040A6305C6708278E7385818F35B751773593FBDC7B9F2DAF2891FC6558839683C104B31BE378DD9EBE740C7BE52DDCD829A348BA008F6B7E0F512BD8C8447DE551F577CD33854EBAF1ABBA63C4AE847D85A32CDDD8ECCADB839EB91F9090502C0012FBDF154436DF3869B6D76F6E5F8DCA447EB19EEE1F8948DEDDC8DFFEE92472340179103AB6533206D370DAA761FD5C605ED28EFEDD87503884272A6B23F2315E40A357BF6B26FEE131C297EA08CD2CC24DD90A25FFB1A7DFDA759AA0A20BA3096E6117AD94C3FA73BA1F766011403432988B5977F6EA8B8D36A7845D825304349BAC2CAA82283055156246C9356004
< OK
> UD0000F0F0E03A8C7362CF3EE871010990CE401D0135AB74D35BA1DF6299FE9360BF701D16EDB71D9E314B0234EF36A589D821A27610DCBFFD7BE50FA8C5CF6E2F793CD50B2BB3518CFD33B961E7B72EC66B645F8B527DC658D00C750B6DE69F85B974764A253FF9A49C98DC4F0ABC7318258086E239B6EBB0E13F6C7810004BE9AFDDB01C08CBAA98723F2C0C226A9AABF20DE3398B8100680094236B417505672AAC6B49D5C723AFB0597DA0CB084C3153ACAD811193FEF47CA5D077D86BA94BD23D22C1415E287BE2370729FF58CF36C96F02C0F0AA4DF879327BA675129B5A3B7CFABBA15D43FBAF539FD97B2ADE9519372546E9
[/color]
Powering up Comfort without UCM/ETH03 connected at all seems fine. Goes to Security Off mode, and then after maybe 30 seconds it says Phone Trouble Controller (so a red herring I assume - no phone connected at the moment since I\'m still bench testing)
Yes Comfort LEDs will be off when the programing cable is connected to it. In this state comfort firmware is not working, the keypadsd beep because there is no polling going on
Please upgrade the UCM firmware to 7.098 by right clicking on the UCM and selecting \"Check for Upgrades\"
see the changes in
http://www.comfortforums.com/forum81/4670.html\\
This fixes a relevant issue
\"Fixed bug UCM/ETH03 upgrade by cable fails 1st time Allow LT to be received without login so UCM can reply OK, not NA.\"
Thanks, I\'ll try that tonight when I get home. I don\'t recall seeing the ETH03 show-up in the list of UCMs on the left hand side though and I\'m sure Scan for Modules didn\'t show anything. I\'ll have to look closely.
Comfigurator was definitely talking to the ETH03 though as I could see the IP address at the bottom of the window and as I mentioned, unplugging the Ethernet cable gave a different error.
You will see UCM- General on the list of UCMs, not ETH03
Comfigurator does not know if you are using USB or ETH03 as the serial interface
Hi, sorry to be a pain but this is still not working.
I manually set IP of ETH03 to 192.168.1.200. I can ping it and CS Manager sees it blue.
Configured it as Network Local in Configurator (even tried all of this on 2 different PCs)
It works to some extent as per previous message about it failing to upgrade my Comfort 5.206 firmware caused the UCM\'s busy1 light to come on. I have also just successfully upgraded the ETH03 sub-module firmware to 2.23 now so that part is definitely working on the LAN and talking to the PC. It still gives the same errors as below though.
UCM green D9 LED is on solid (slightly dim, maybe flickering very slightly?). I only noticed the red D10 LED come on very briefly once so far.
[color=\"#ff0000\"]UCM Leds D9 is RED and D10 is green. D10 green will blink rapidly, D10 red should blink more slowly
[/color]
ETH03 board has solid green and red light which is good.
Tried to scan for UCMs - asks for sign-in code. Finds nothing and says \"Failed to connect to UCM\".  Without that working I seem unable to upgrade the UCM\'s firmware. Feels like a Chicken & Egg situation.
[color=\"#ff0000\"]Upgrading UCM Firmware does not need a Login as long as the connection is good, as you have confirmed
Just Right Click on the UCM select Check for Upgrades\" This will upgrade the UCM firmware
[/color]
Tried it with and without main Comfort UCM Programming cable connected. Still gives the same \"failed to talk to UCM message\" in all cases.
[color=\"#ff0000\"]If the Comfort Uograde has failed do a Reset on Comfort in order to get out of the Firmnware upgrade. You should hear security off, and the UCM D9 and D10 should start blinking again
[/color]
The UCM SW7 are all set to ON which should give it ID1
I also tried it with the \"New method\" of setting ID to 1 by using SW7 all OFF and the COPY button - no difference.
Please can you give me any further suggestions? This is very frustrating. I was hoping that a brand-new UCM/ETH03 would allow me to bring my old Comfort 5.206 to the 7.xxx firmware and then have the benefit of having it on the LAN too. I haven\'t even unpacked the new UCM/GSM4 yet - I hope I don\'t have similar issues with that.
I just noticed another forum post suggesting a DOWNGRADE of ETH03 firmware to 2.01 if you cannot talk to the UCM but surely since my UCM/ETH03 has only just been sent from Cytech to the UK (via Hunters Wholesalers) this week then the base UCM firmware will be fairly new anyway so shouldn\'t have this problem?
[color=\"#ff0000\"]You should not need to downgrade ETH03 firmware[/color]
Please do the following and let us know the results
Without The UCM programming cable connected to Comfort, what are the states of the D9 (RED) and D10 (Green) LEDs on the UCM?
if the UCM is working correctly, the RDY Green led should be on and both red and Green leds should be blinking (The green led appears solid because it is blinking very fast) If both are blinking then skip to the next section
If the Red D9 led does not Blink, you will not be able to log in.
Are any of the BUSY1, BUSY2 and ERR leds also on? This may indicate the UCM firmware was corrupted because of an earlier attempt up upgrade the UCM firmware (Not Comfort firmware). Not to worry, the UCM firmware can still be upgraded if it is corrupted by following the instructions below.
Without attempting to log in, do a firmware upgrade of the UCM firmware by right clicking on the UCM in the Modules Tab and selecting \"Check for Upgrades\"
If you have an error message, ignore it and repeat the Upgrade operation. If there is a message to do \"Scan for Modules, - Yes/No?\"select NO. The repeat upgrade operation  should succeed
Upgrade Comfort Firmware using UCM programming Cable
Once the UCM is working and has been upgraded to 7.098, ie D9 and D10 leds are blinking, then do the firmware upgrade using the Programming Cable connected to Comfort. Even if D9 and D10 do not blink, but the RDY green led is ON you can go on to the Comfort Upgrade
To do the Comfort Upgrade, once the Programmming cable is connected do not attempt to log in as that will fail
Go to Transfer > Upgrade Firmware using UCM programming cable. Select the cbf file for Comfort Ultra 7.xxx
If you get an errer message \"UCM does not support this operation\" repeat the firmware upgrade again. Ignore the message \"Scan for Modules \", enter NO as scan for modules will not work. Just repeat Transfer > Upgrade Firmware using UCM programming cable. Select the cbf file for Comfort Ultra 7.xxx
If there still are any problems, copy the Monitor IO and send it to us
The UCM IO Monitor when upgrading Comfort by UCM cable using UCM 7.098 is shown below
> LT01
> LT01
> LT01
> UB0100FA
< OK
< OK
< OK
< UB01F0
> UB02
< UB02
> UD03FEF0F0A832161277B0A3F0B4169BAF5059CCC3333D3EBABA02E69F5319369E5B0591855319369E5B0591855319369E5B0591856CBE36595C5E07B61A474411BAF507D8BBBEF12081D6BF6C84EFBF2EBAB65773BFE186FCF51F0CA8DE2CCE28C6D130569D1CF6F221E5F2A4C718E0786080C234656A2C32D84084ACA2CDF9BE2B5626CDE45A92A4A85990846CA88D68958B42A5F52A9731E9A512105C594C4A00E1AA73994D9B99733D097F49CE3DD0368599E95319369E5B0591855319369E5B059185FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
< OK
> UD000000F0B24C968EEF68037B280F0D0ADA41787E1A2788CC6FC3EF94FAA8EE0693E910BDA55AB68237F96677C12EE174EBED197D1ADF9740E979DDC1D364022A763A496E4F9F7EAD510CFD13074B2D46B43496503A81EF2954CA1B87F314DA9E7E5D2187252BF03A96DAE7CD58B0A0D5AE4CA92A65FAED349B718A5221BC45A12C9ABAA7D90E375339F98490E9DAE8B99C7DCF54A71A131BF396FCCC9DC7EB57E718418D3D044E309500D034E49A4F1664CF76FDA18AABD35B164D8A11816B7DCA11831F56615C7B559C55963ADE07103979433CE2A974F3E624E8E3F2C38824894665C4F3D3F2624CCFA4BE0118351221FBB5296B
< OK
> UD0000F0F058316AD228A6CDCFF2D850BDF560323F1D92250569308702C6053DA178D1FB22A566F43B7ED4BF5BEFD99912F201C5D6DC8126DCE3F94CADB6F519CCB5E29C513B5EAB3E6AA3AB84BB87F7CF0F688FDCA91DDCC572A71C1B5ADC1D1C6280EA9351A85CD64D09A7CE615A54CA08119ACD10004BE9AFDDB01C5EE4E445574EC42050AA3354F14A109D9B39A810C0C52754EC8D1950FD2724FDA578B860429685A2D75F9295D57B2C5320F9487AD660D0A87A68531992294DE0C9AD54E4F03624BFEB66DA2C9051F77EF38BC3D159D01B09278A30055F25AD3D830453C83D35F9706CDCB11C75CE4711515B0D44F2104F1D65
< OK
This shows the firmware upgrading in progress, and will com,pl;ete without any problems
