Threads: 1
We have just moved to a house with the comfort system installed. The phone worked fine until someone rang the bell at the gate and I answered the phone. Now picking up the receiver I just hear \'phone trouble please sign in\'.
I have plugged the phone into the Bt test socket (behind the face of the Bt master socket) and it works fine. However, all other sockets are still phone trouble and there is another alarm system (CIA) who need the phone line and say they can dial in as the engaged tone is hear.
How can I clear the line?
Threads: 31
02-19-2017, 05:35 PM
(This post was last modified: 02-19-2017, 05:36 PM by Swiss-Toni.)
If you have comfigurator try re setteing the system if the problem persist it could be to do with your are not terminatting the call when the doorbell is pressed and you answer it with your phone. the only other thing I can think is that their maybe a problem with the way the phone is wired in the comfort system.....
Threads: 1
How do I get comfigurator?
Threads: 31
Download it from cytech.biz also you can open up the panel and where the telephone line goes in and out disconect and (pull out plugs) and then bridge connections to see if the problem is on the line there.
There is a reset button inside the panel but maybe hidden behind a sem/lem if you have one installed it just covers it.
Threads: 885
Also you need a UCM in order to use Comfigurator
Threads: 1
Sorry to sound stupid, but what is a UCM? I have managed to download comfigurator but it says I need a UCM...how do I get one and what is it please?
Threads: 1
Thanks but I\'m reluctant to buy one as I won\'t know what to do with it when it arrives. I\'m trying to find someone who is able to visit the property to do all of this resetting business for me. The phone was fine until I answered the gate with it. That makes me think it\'s no wiring that\'s a problem. The phone still rings when someone is at the gate, then returns to \'phone trouble\'.
Threads: 885
Ringing the phone does not involve the telephone line or a fault with Comfort (less likely)
The symptoms are consistent with not having the phone line connected to Comfort
What is your location, so that any Comfort installers can see if they are able to help
It is best if you know the original installer. There may be contact details written on the controller enclosure
If you can see the serial number on the Comfort PCB starting with C.... or P... that may also help to trace
