Releases (Latest at top)
Release 1.0.1a
This is the latest release
Download disk image here 1.0.1a.img.zip existing users may upgrade using the Upgrade button in the Web GUI
Supported Devices
  • Samsung SmartThings
    • Inputs, Outputs, Flags, Counters, Alarm Mode and State, Responses, Doorbell.
Changes
  • Fixed: alarm.config.template no contains windows LF and can be easily edited on Windows machine. Existing users may download a good alarm.config.template file from here: alarm.config.template
  • Fixed: Alarm Mode change to mode without a SirenName entry in .cclx causes restart of service
  • Fixed: Changed update process to get update file synchronously. Previous updates may fail if file is not downloaded fully before starting update.
  • Fixed: Registration with send usage data flag now correctly registers
  • Enhancement: Add link to release notes on Web GUI
  • Enhancement: Add link to Forum and Mailing list on Web GUI
  • Enhancement: Updated ComfortAlarm Zone Device now includes Capability.ContactSensor allowing it to report Open/Closed as well as Motion/No Motion
Known Issues
  • Discovery is limited to around 130 devices depending on length of device names. Please contact support if you have more devices for process to discover many devices
Notes
  • You will need to update the ComfortAlarm Control device from the SmartThings page in the Web GUI in order for the Doorbell device to function properly.
  • You will need to update the ComfortAlarm Zone device from the SmartThings page in the Web GUI in order for the Zone device to report Open/Closed
Release 1.0.0a
Download here 1.0.0a.zip
Supported Devices
    • Inputs, Outputs, Flags, Counters, Alarm Mode and State, Responses.
Known Issues
  • Door Station Bell Button push will cause a restart of the UPNP manager; impact will be loss of communications between Comfort and UHAI devices for up-to 10 minutes.
  • Requesting a stop of the UPNP manager via the web GUI when it isn\'t running will result in an error message. Service availability is not affected.
  • Registering with \'send usage data\' checked will not complete. Service availability is not affected, uncheck the \'send usage data\' checkbox to complete registration.
Release 1.0.0c
Download disk image here 1.0.0c.img.zip, existing users may upgrade using the Upgrade button in the Web GUISupported Devices
Changes
  • Fixed: Doorstation doorbell press event no longer causes restart of service
  • Fixed: Start, Stop, Restart on the web GUI only available when the service is in the appropriate state
Known Issues
Notes
