01-19-2017, 03:34 AM
I am slightly confused when the PIR off response on a zone is initiated.
Has there got be at least one ON response activated before an Off response?
What happens if there are no ON responses?
For presence detection to switch off lights or heating in a room, I am finding that there must be at least one ON response. If the situation is such no one enters the room and the PIR does not detect the person due to location of the PIR relative to the light switch then the OFF response will not be activated.
If this is the case, how would you suggest I program the presence detection when there no PIR on\'s so that PIR off can still be initiated.
Do I have attach a response to the light switch or heating to know that the heating ir light is on in the room? Am still able to PIR on/off one the zone possibly with extra programming attached to the light switch?
Thank you for support and help you give through this forum.
