Keypad volume anomaly
Having suffered the failure of two keypad \'speaker\' modules, I am very aware of the very sensible advice given that I keep the volume at a lower level to possibly avoid yet another failure in the future. After fitting the third module, I lowered the sound level to 40 and have been very happy with the quieter voice. However, I notice that for certain functions, the voice level clearly reverts to its default value of 50. For example, I had a message waiting today and after listening to it (at the lower volume level), I pressed # to exit the system. I then got a - booming! - \'security off\'. It is much more noticeable now that most of the sound is at the lower lever - when it changes, it almost sounds like the lady is shouting!! Smile
My main concern is that IF it was a \'default too high volume\' that caused the early failure of the two previous speakers, isn\'t this adding to the \'stress\'? Is there any way that I can set ALL communications to the level I set, whatever that might be? And- if not, why not?
There is a separate setting for keypad announcement volume, diferent from the individual keypad volumes for voice menu
This is in Voice Settings > keypad announcement level
You may want to have a low volume for the voice menu, but a higher vcolume for announcemennts eg for alarms, so you can set an announvcement volume
Thanks so much. I should have checked more carefully! I hadn\'t realised that there were separate settings. All is now good.
