Threads: 2
I am looking to add a UCM ETH03 to my Comfort Ultra II and have a few questions please;
I have owned Comfort II Ultra for around 10 years now and am running very old firmware v5.121.
I also have a CBUS UCM with firmware v5.134.
Can you tell me if I will have any problems updating my firmware using ETH03?
Also, I have a Cat5e cable running from my Comfort Enclosure to my Wifi Router. Will I be able to connect to Comfort via my laptop using my home wifi?
Finally, using ETH03 will I be able to connect to comfort via my android phone using the Comfort App?
Many Thanks
Dave
Threads: 219
Apart from the Cbus side which I\'m not familiar with the answers are otherwise YES for all of your questions IMHO other than will you have problems upgrading! You may have to upgrade Comfort ULT firmware the first time with the programming cable but after that it is all upgradable via Comfigurator and Ethernet connection IMHO.
I\'m hesitant on the CBUS side because (a) not my area and (b) I think a replacement CBUS2 daughter card may be involved somewhere in the mix somewhere here?
Ju
Threads: 886
We do not have record of Cbus 5.134
Prior to Cbus 5.154 (up to 5.75) the UCM/Cbus was not upgradable
From UCM/Cbus 5.154 the firmware is upgradable, so re-check what is the cbus firmware
Threads: 2
Hi. Thanks for your replies. The C-bus UCM has a hand-written firmware number on the front so it probably is 5.154. It is a little difficult to read. I am mostly interested in the Comfort firmware upgrade however. As long as I can upgrade the v5.121 comfort firmware I would be happy.
Juwi_Uk can you explain what you mean about upgrading Comfort firmware with the cable before upgrading with comfigurator via Eth03. I have never upgraded firmware so Im not sure what you mean. How would I do that?
Threads: 2
I follwed the link above in order to upgrade comfort firmware via the programing cable however I repeatadly get the \"Failed to connect to UCM - please check UCM connection settings\" message.
I completely removed the CBus UCM as i wasn\'t sure if it would complicate matters if the programming cable was attached to that instead of the comfort board.
I connected the cable as shown and applied the PP2 shunt to the comfort board.
The keypad beeps continuously.
After starting comfigurator I set the UCM interface to Network (local) and set the ip address. Then I try the firmware upgrade routine as written.
Is there anything else you can think of that I am doing wrong.
I have since upgraded the Eth03 firmware to 2.20 and that worked fine. This did not help however.
No transfer of data from comfort is possible.
Just to be clear I am attempting to upgrade my 5.121 comfort firmware with a brand new etho3 UCM. I have never previously been able to upgrade firmware or program comfort other then via the keypad.
Any help is much appreciated. Thanks.
Threads: 886
10-31-2016, 06:12 AM
(This post was last modified: 10-31-2016, 06:16 AM by slychiu.)
When Upgrading firmware by UCM cable and after connnecting the programming cable do not attempt to log in as Comfort will not respond
Immeidtaely go to Transfer > Upgrade firmware by programming cable and gselect the cbf file
When the programming cable is connected Comfort does not function and al the keypads will beep
You do not beed to remove he Cbus UCM or keypads during this process
Also using UCM/ETH03, the first attempt may fail due to an error, but please repeat the process
Threads: 2
I have not logged in as I read that this would cause it to fail.
Are you saying I should try and perform the upgrade through the CBus UCM and connect the programming cable to the CBus UCM instead of comfort? The Cbus UCM sits on top of comfort and so I cannot connect the cables to the Comfort board when the CBus UCM is in place.
I was worried that it may try and upgrade the Cbus UCM firmware instead of the Comfort firmware if I did this.
With the Cbus UCM removed I have made repeated attempts to upgrade (when not logged in).
Presumably the Eth03 UCM as shipped to me will have the correct and compatible firmware? Note that I have since successfully upgraded the Eth03 firmware to 2.20
Threads: 886
No you should not use the ucm cbus for upgrade
Can you connect to comfort through the ucm eth03 when the ucm firmware cable is disconnected?
Try to login normally without the ucm firmware programing cable
