Comfigurator automatically backs up every version of cclx file, so that you can restore an older version of your configuration
Go to File > Restore from Backup
Select the cclx file. The screenshot below shows all cclx files that have been used on the PC. In our case, we work with many files, but in most cases you may only have one or 2 filenames.
After selecting the file, select the backup date
This restores the version selected
The backup files are saved in C:\\Users\\(user)\\AppData\\Roaming\\Cytech\\Comfigurator\\backup
You can purge the unused files from this folder if no longer needed
