Comfort Firmware 7.099 (changes from 7.093)
Known Bugs
Known Bugs
- Execute Response in Comfigurator (DA) with multiple actions - security alarm actions eg bypass, Do Alarm cause subsequent actions do not work. eg Bypass zone 1, bypass zone 2, output 1 on Only Bypass zone 1 will work. However the Response executed by Comfort events will work
- Actions Add counter, Add counter give wrong answer from 7.039
- Time change from KNX and Cbus group address are ignored
- CM9000- OPT firmware bug Clear all outputs action 8 does not work
- Do Action 190 serial command DABE does not do the actions following action 190 correctly. The 1st action is continually repeated
- Action 73, 16 Get keypadId/ If Keypad ID does not work
- When several Keypads were reset together, sometimes one of them would show \"Wrong text - press *1 to sync\"
- Fixed occasional problem where the zone restore was not sent to SMS or CMS after the same zone caused alarm and sent SMS or CMS alarm.
- Fixed old BUG where ETH03 is used to update date and time in Comfort from Internet time. During Daylight saving time, adjusted time from 12AM to 12:59 AM was set back to 11 PM to 11:59 PM. The time is correct from 1 AM onwards.
- When a zone which caused alarm is restored, record zone restore to event log. Before only zone trouble restore is recorded in event log.
