Threads: 3
My Doorbell is set to dial my mobile phone when Comfort is Armed, but the call is disconnected after a period. How can I change the configuration to allow an open ended conversation with the visitor?
Threads: 885
The timeout for the doorstation is 45 seconds, after which the menu will say press 0 for door station. This allows you to continue. It should not cut off and hang up
Is yours comfort 1 or 2?
Threads: 3
Believe it\'s Comfort II, SY. Call cut out after what seemed to be longer than 45 seconds, but did not get \"press 0 for door station\" message.
Threads: 885
what happened after the door station mode stopped? was the call cut off ie system hang up? or was it still connected?
Threads: 885
can you try to call in to the line. sign in and and press 6 for door station
Does this also cut off after some time?
Perhaps somethong else is cutting the line
Threads: 3
Comfort says : \"Select Station 1 to 2, 4 to open Gate, 7 to open Door\"
Selecting#1 opens line to Front Door Station and line stayed open for at least 1 and a half minutes, so why should it cut-out when it\'s activated from the Doorbell itself?
Threads: 885
when you called in, after time out did you hear the menu \"Press 0 for door station\" to allow you to continue
This is what should happen for dial in and dial out
Threads: 3
No, waited about 1 1/2 minutes then I disconnected. No message.
Threads: 885
what is your comfort version? Please send your cclx file so we can test it to support@cytech.biz
The menu should cut in after 1 minute or so. This should happen for Phone to door station, Phone to Keypad and Keypad to door station as well ie Keypad menu press 6
