03-16-2016, 11:46 PM
I have Heatmiser and it is running well. It controls DHW, underfloor electric and thermostats. All timers are controlled by Comfort. DHW timers removed from Heatmiser, DHW thermostat and timers are in Comfort. Home, Away and Night mode setting off or on heating as needed. Great.
I have the Heatmiser runmode mapped to a counter. Looking at other CBUS threads, will a response mapped to the runmode counter activate its response when a person changes Thermostat button from heating to frost protect or visa versa.
I understand from the CBUS thread if a response mapped to a CBUS counter, then CBUS changing the counter will activate the response, but a response changing the CBUS counter will not activate counter response. Fine.
I need to use zwave modules that will control radiators where a pilot wire sets the fans speeds (set backs) and on or off. ZWAVE do pilot wire controller. I want to the run mode counter response to various things.
Can heatmiser counters have counter responses that are activatable.
I can not activate counter response for a Heatmiser Counter Run Mode from a human pressing the Heat or frost protect mode button.
Your help will much appreciated.
