03-14-2016, 04:40 PM
If the ETH03 firmware is corrupted perhaps due to a failure to upgrade firmware, follow the procedure below to reset the ETH03 to initial settings including DHCP
- Press and hold SW2 switch.
- Press SW1 RESET once.
- The Green D2 LED on the ETH03 will turn off for about 5 seconds and then turn back on.
- Maintain the press-and-hold of the SW2 switch until another cycle of turning off and turning on of the D2 LED on the ETH03 module. This will take around 10 more seconds.
- Run the CS Manager software to discover the ETH03 module.
- Upgrade the ETH03 firmware if necessary
