Comfigurator 3.11.1 to 3.11.2
Comfigurator 3.11.0 beta can be downloaded from https://www.cytech.biz/comfigurator.html.
Note: This can no longer be downloaded as it ihas been replaced by 3.11.1
Users are advised NOT to upgrade to this version unless they want to test a specific feature
The changes are;
Known Bugs
  1. Writing to EEPROM for UCM/KNX writes  empty data, so the group addresses mapping is lost. Do Not write to KNX
  2. Read from Comfort does not work - It removes all the Modules from the modules tab
  3. For Selective Read for any comfigurator item, if the referenced Response is not present in Comfigurator responses, then the response becomes Null. eg If Time Program references Response 100, and Comfigurator does not have this response, then the Time Program response becomes Null Response. This is not a new issue. Selective Read should be done only for information purposes. A Full Read from Comfort is needed to know the correct program in Comfort.
  4. Register References for TSM and HIO are not shown
  5. For IRIO \"Show References\" does not include the \"Summer/Winter Flag Name\"
  6. For IRIO, ISM07 Relay I/O, Blinds DC has \"Unhandled exception\" error when clicking on Pulse width. After changing Pulse Width or Min Pulse Gap, the properties of the submodule cannot be changed. The previous settings are reverted to.
  7. For IRIO, Read from IRIO always has Travel time = 254 seconds
Bugs Fixed
  1. Comfigurator 3.10.11 could not install on Windows XP.
  2. File > Update Defaults did not work in 3.10.11.
  3. In Zwave, after doing a Learn from Zwave, Flag mappings were changed into Counter in Zwave Mappings.  This bug was in older versions of Comfigurator as well.
  4. [color=\"#ff5500\"][color=\"#000000\"]Virtual Node in Zwave Configurator  Virtual Node Info - SEND button n the right pane was missing from Comfigurator 3.10.9
    [/color][/color]
  5. [color=\"#ff5500\"][color=\"#000000\"]IRIO Get status did not work[/color][/color]
New Features
  1. For IRIO, the control and feedback registers have been changed. Control/Feedback Register combines the main Control and Feedback register into one register so that the user does not need to specify a separate control register and feedback register if they are the same. 3 other control registers allow scenes
  2. For IRIO, each Submodule properties window shows a summary of the assigned Outputs and Inputs Functions without having to select each Output/Input to find out the Function assigned
  3. In the Control Menu, if Feedback Type = Output, Zones, or Flag is selected, the action Keys 0 and 1 are automatically entered as Off and On respectively. This saves time in programming the Control Menu especially for use in the Comfort app. In a future Comfort firmware upgrade, pressing the Off and On buttons wil automatically cause the Flag, Output to be turned on or off.  However the \"Off\" and \"On\" words  cannot be seen in the Control Menu unless you go to another page and come back to it.
Comfigurator 3.11.0 Bug
Do not Read from Comfort
Also please refer to the list of bugs in the first post
Comfigurator 3.11.1
This fixes  bugs  in 3.11.0. Those who have 3.11.0 are advised to upgrade to 3.11.1.
Known Issues
  2. For Selective Read for any comfigurator item, if the referenced Response is not present in Comfigurator responses, then the response becomes Null. eg If Time Program references Response 100, and Comfigurator does not have this response, then the Time Program response becomes Null Response. Selective Read should be done only for information purposes. A Full Read from Comfort is needed to know the correct program in Comfort. (old bug)
  3. For Graph References, if there are any references to HIO and TSM modules (new unreleased modules), an un-handled exception is seen
  4. In IRIO, any input function after selecting  the Register Type (eg Couter, Flag), is not able to select the Register Number (Counter or Flag number). The workaround is to go to another Input or screen and come back to the input to select the Comfort register.
  5. For KT03 using Counters and Outputs, the Counter and Outputs Reference to KT03 is not shown in blue in the Counters page and Outputs page (old bug)
  6. When the cclx file wordlist does not match the vocabulary (Voice) in Comfort, logging in to Comfigurator will change the wordlist to the one in Comfort, but the words selected in Zones and Control menu are still the wrong wordlist and the words written to Comfort will be the worng  wordlist . To work around, the Wordlist in Comfigurator must be changed manually to the one on Comfort before doing a write to Comfort (old bug)
  7. Reading from Comfort does not read the Daylight Saving table into Comfigurator (in Sunrise/Sunset Times), although the Sunrise/sunset times are read. (old Bug)
  8. If  UCM/Cbus2 is present, all zones are referenced to UCM/Cbus2 because of the Cbus2 Physical Inputs, even though the Physiacl Inputs are not mapped to Cbus (old Bug)
  9. In Flags, if Check Status box is checked for a flag, the status is updated, but if the flag changes subsequently, the flag status in the centre pane is not updated until you go to another page and back, or uncheck and check the box (old bug)
Bugs Fixed
  1. Read from Comfort  removed all the Modules from the modules tab
  2. Register References for TSM and HIO were not shown. However now Graph References causes exception.
  3. For IRIO \"Show References\" did not include the \"Summer/Winter Flag Name\"
  4. For IRIO, ISM07 Relay I/O, Blinds DC had \"Unhandled exception\" error when clicking on Pulse width. After changing Pulse Width or Min Pulse Gap, the properties of the submodule cannot be changed.
  5. For IRIO, Read from IRIO always has Travel time = 254 seconds
  6. In Control Menu, after selecting Feedback Types = Output, Flags or Zones/Inputs, the words for 0 = Off and 1 = On are automatically entered. This works correctly now.
New Features
  1. Support for new UCM/KNX2 with enhanced KNX Interface. UCM/KNX2 is still being tested and is not released yet.
  2. Graph References hover remains on for 30 seconds (instead of 10 seconds) so it is easy to read the Responses.
Comfigurator 3.11.1 has been released
Please check the known issues in the last post which are mostly old bugs or related to IRIO
Another version shall be released to fix the issues remaining, but 3.11.1 does fix a number of issues with the last version 3.10.11 so please upgrade
Bug found in Comfigurator 3.11.0 and 3.11.1
Writing to EEPROM for UCM/KNX writes  empty data, so the group addresses mapping is lost. DO NOT write to KNX
This bug was from 3.11.0. It will be fixed in 3.11.2
The write to EEPROM Bug for UCM/KNX will be fixed in Comfigurator 3.11.2
Comfigurator 3.11.2 fixes the following bugs in 3.11.1
  10. If Comfort Voice is lost, Comfigurator produced and exception
Comfigurator 3.11.2 has been released
Please upgrade
