Threads: 29
This link seems to be dead.
Threads: 8
Hi Chiu,Is there a new link?Actually I am looking for a solution that would let me send orders to comfort ( html, json,php) and get status back through the net. Would it be possible to get the right set of commands or better any script that I could integrate in my home automation system?Thank you
Threads: 8
Thanks Chiu. I am a newbie..Would there be any existing scripts to learn from? Any source code to undersatnd how and what to program in php or json to address comfort?
Threads: 885
The Comfort protocol describes the commands that can be used to control and monitor Comfort by Ethernet, RS485 or Rs232 medium.
If you use UCM/ETH03, an IP address and port is assigned to the UCM, so all commands are sent to the IP/Port
XML or JSON is not a suitable way to communicate with Comfort, as the UCM or Comfort is not implemented as a server to process these.
The introduction to the protocol document describes how to start off, and how to send a command and the typical commands that can be used
