11-18-2015, 09:50 PM
Hi Experts,
I am configuring a Comfort SPC with UCM/ETH03 and UCM/KNX link to Siemens Combi N502/02.
In KNX, I have setup to the Switching module as below:-
0/1/0, 0/1/2, 0/1/4, 0/1/6, 0/1/8 for 5 lights control
0/1/1, 0/1/3, 0/1/5, 0/1/7, 0/1/9 for 5 lights status
In UCM/KNX, I have setup 5 Counters (Counter 001-Counter005) to 1-bit Switching of KNX to get status of 5 different light status (KNX Status Address 0/1/1, 0/1/3, 0/1/5, 0/1/7, 0/1/9).
In Configurator, I have setup 5 Responses to Turn On/Off for 5 KNX Switching (KNX Address 0/1/0, 0/1/2, 0/1/4, 0/1/6, 0/1/8) using 1-bit.
Then, I setup Control menu accordingly to control 5 lights on off and Feedback Type to Counters (Counter 001-Counter005).
It works nicely and I can get the feedback from KNX after switch On/Off.
Then, I want to add a Scene button to Turn All Light Off/On.
So, I created 2 response, 1st Turn All Light On (Execute all the 5 Turn On Light responses), 2nd Turn All Light Off (Execute all the 5 Turn Off Light responses).
When I try to Turn All Light On/Off, I cannot see the status updated to Individual Light control menu. BUT, if I logout and login again, I will see the status updated.
I try to monitor the status in KNX, when I execute the All Light On/Off responses, status are replying from KNX. Which means status is sending back to Comfort.
I check the Control Menu status in Comfigurator, I am getting 0 / 255 after Scene control of All On/Off.
I have tried to Initialized Counter value to 0/255 in All Light On/Off responses, but it still does not show the correct status.
May I know how to overcome this issue? It seems like the Status in Android application is not refreshing after I execute the Scene Control.
Please get back to me as soon as possible because our project is closing soon.
Thank you!
Thank you!
