Comfort 7.083 Beta
Changes from 7.078
Known Bugs
  1. changing sensor values does not work. eg s!nnvv set sensor register does not work. Other ucms which change the sensor value also do not work
  2. If UCM IS #1 is not installed, if there is a Line Cut at Reset, it will cause the system to reset continuously - This firmware should not be used, it has been removed.
Bugs Fixed
  • FIX BUG - if Disable Line Cut box is not checked and Misc alarm Line Cut Alarm = 0, 1 alert zone will cause intruder alarm.
  • Fix BUG Logic engine slider cannot work send CMGGCCxx problem found by Seah ITE
  • Fix Bug from 27/12/14 in alarm state, tunred on broadcast for keypads and this remains enabled eeven after disarm
  • Fixed bug from 7.077.  v! did not work unless full vocab transfer is done. sentence upgrade alone failed
  • Fixed Bug for Action 155  - Send Custom SMS message # parameter inst of phone # for event log. added another event for custom message #
  • Fixed bug when event log goes to 1st or last event, it did not announce the event menu, it used to go back to announce the same event
  • Fixed bug gsm id was always 0 for a? Reply
Event Log
  • Added event type for Send SMS Custom message # for action 155 for gsm4. Event will announce number and \"new message for\"
  • Event Log announcements start from last event and play backwards in time. But Read event log in Comfigurator still is from 1st to last.
  • Event log when press keys 5,6,7,8  do not announce \"wrong code\"  immediately announce the event menu
  • Alarm history go to last event not at alarm history pointer, now the same as event log.
  • Event log events battery warning, Phone Line trouble, system reset , Voice Fail etc all will have parameter 1 instead of a random number
UCM Commands
  • AMFF will not be reported  when the zone alarm has no Nondetector alarm eg Alert/Perimeter
  • Implement  reply to reminder query RM
  • Allow module scanning for ID7 (Sensor) and 8 (HIO)
  • If Nondetector alarm for Phone trouble = 0, AM04 (Phone trouble Non detector alarm) will not be reported
New Features
  • Duress code only need to enter 1 time, instead of 2 times, in order to avoid problems
  • Action 86 Check Timer Action return 0 if not running, and returns the Remaining Timer value in seconds if timer is running.  eg DA5601 (Do action 86 Check Timer 01). Reply RA8001 means Timer remaining time is  128 +256 = 384 seconds. This allows checking of timer to be implemented in Comfigurator.
  • Implemented Execute Time Program Response command TPnn02 (nn = time program number in hex). This allows a command to execute the Response for the Time Program directly
  • If a zone changed to Off without being previously ON or Trouble state, then Off Response is not activated (applicable for rare instances)
Bug in Firmware 7.083
