09-22-2015, 05:10 PM
BUG in KT03 Firmware 7.072
Please note that there is a bug in 7.072 firmware. The firmware works but upgrade to a higher firmware by direct connection to USB or via another UCM will not work. It will result in the KT03 having a blank LCD and not being able to start. The only way to upgrade this firmware is by programming cable
This firmware has been removed from the server
