Rly01h as dimmer button control ( bell button type )
Anyone has experience programming comfigurator in order using RLY01H acting as bell button to control a dimmer control ?
Bell button that i mean is : for on/off by short press for dim up/down by long press
The RLY01H is a relay which works simply on an open/closed circuit triggered by an output for upping voltage ect. if your using a non voltage bell button this should be added to a input and the appropriate programming implemented. Im not sure if this is what you meant, im only going by what you haven written.
Hi Toni,
Actually i need \' bell button simulation \' at output side. I plan to control a dimmer control ( see attachment) . It need a button type . So i plan using rly01h to act like bell button . So how to program comfigurator to do so ( short press and long press ) ... or short press = momentary press
And is it possible to program  the user interface at android to show \'ON\' and \'OFF\' button and one \'slider\' to represent long press with counter range
You can connect a push button to zone, make it ZoneType Switch Normally Open
On Response = Output N On Off Response = Output N Off
This is the same as using a button to press the switch on the dimmer
So at phone user interface will be appear as 1 button ? And when we press the button become close from Normally Open until we releasing the button in the screen ?
Press and Hold is not possible in the Comfort iphone appThe control menu allows you to send any ciommand eg Pulse output for 1 second 2 seconds etc but it cannot dim or brighten to an absolutre level becauase the device does not tell its feedback status
.....You can connect a push button to zone, make it ZoneType Switch Normally OpenOn Response = Output N On Off Response = Output N OffThis is the same as using a button to press the switch on the dimmer......
[color=\"#004080\"][font=\"Verdana, sans-serif\"]
[/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]
[/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]So what does \'above\' mean , is not same as bell button function or \'press and hold \'  ?  [/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]
[/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]If i need one button that only send momentary pulse ( e.g 100 ms ) . Regardless dimming function. I only use comfort as redundant of physically button at the wall.  And the button ( at android apps ) also can reflect the status ( like standart interface on off in lamp ) .. so : [/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]
[/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]1. How to program comfigurator ? With nice appearance like standart button lamp at android app ( not \"text\" button )[/font][/color][color=\"#004080\"][font=\"Verdana, sans-serif\"]
[/font][/color]2. C[font=\"Verdana, sans-serif\"]ould i use rly01h at output side and  combine with current sensor at input for status ?[/font][font=\"Verdana, sans-serif\"]
[/font][font=\"Verdana, sans-serif\"]3. If all can program like above, how to create virtual nodes so from zwave controller it is acknowledged as normal/standart on off lamp device .[/font]
Am i right if output with \"blind operation\" is quite similar with i expect to control the dimmer control ? could i use this type of output with this connection modification :  up and down in blind operation  connect to 2 relays right ?  for dimmer control i connect both relays at same input ( switch input at the dimmer )
I think what you are actually saying is using the RLY0H as a momentary switch which you would have to configure as a pulse from the output to trigger it one step at a time, the module the Hytronik module then does the work for dimming?
However I do not see how you completely turn of the module unless that is also wired through the relay to break the circuit!
(Basically you would have to configure the output to activate for argument sake 1 sec and then press again to repeat action causing the module to dim as required!)
Just looked up the module and you would have to configure the relay for bursts of whatever time and then a separate button to do a short burst to turn off.
However because of the nature of the apps unless you per-program a sequence you would have to follow the same process of tapping app button to dim and separate one to turn off.
I think the way you have described things initially has caused confusion as to what you wanted to achieve
Hi Toni
I apologize of my confusing explanation.
Turn on, turn off and dimming can be done by one switch ( bell button switch type ).  Yes short press will make the switch become \"momemtary switch\" and the result are turn on or turn off. For dimming we should long press the same button and the result are dimming down or dimming up. To get the dimming level , just relase it in the level we want
Anyway idea with 2 button , maybe suitable for this project
