07-19-2015, 10:16 PM
I have had problems trying to work out the best use of sensors to turn lights on stair treads and wonder if it would be possible for Comfort to manufacture something that i have designed as a solution for this problem,
I thought of using a standard PIR and pressure mats and then decided to make my own using a micro pir module and a push button that I modified blending the two together (16mm button one with an illumination ring as this supports the module) . the pictures show roughly how I went about it and the only the problem that I encountered on the installation was the correct programing (It has to be set as \"digital\" as it only use a 3 wire connection) The overall diameter of the pir in its new housing pushed back to reduce activations is the size of a penny (UK) so quite small.
(Can only put one picture on at a time so will be spread over a few pages)
