05-31-2015, 10:24 PM
I have mapped the temperature sensor of an SCS8 to an entry in the control menu, but it always reports in Fahrenheit. I would like to have the announcement in Celsius. In the SCSman.pdf it says:
However, I found this in the firmware section:
My version is 2.004. The current value of location 0039 is 168, but it makes no difference when I change it to 169 and reset. Please advise how to change to úC.
Quote:The temperature may also be announced in either ÃÅ F or ÃÅ C. The default setting is in ÃÅ C. To change the settings to ÃÅ F, the total value of location 39 (as shown in the ââ¬ÅComfort II Ultra Program Worksheet (FS34)ââ¬Â) must add an additional value of 1. This is to be done via the Location Menu in the Engineer Menu on the keypad.
Note: Changing the value of location 39 only changes the announcement made by the keypads and does not change the value of the registers.
Quote:Version 2.004 ââ¬â 22 June 2010
Support temperature sensor report in Celsius. Take note that the temperature unit now is 0 for Fahrenheit and 1 for Celsius, which are the reverse from previously.
