KT03 7.070
Known Bugs
Changes
Known Bugs
- IR Receive in KT03 does not work
- Display of Output status above 64 does not work
Changes
- Supports Zone Name Element (requires Comfigurator 3.10.4), see http://www.comfortforums.com/forum90/4218.html
- Supports KT03 System Properties (Beep On/off, Speaker On/Off, Announcements On/Off, Screen Timeout, Backlight On/Off, IR Receiver On/off, Speaker Internal/External, Tamper On/Off) which were only accessible via the KT03 settings screen, can now be changed in Comfigurator. KT03 System Properties Read and Write without having to read/write all of KT03 will be supported from Comfigurator 3.10.4 See http://www.comfortforums.com/forum90/4216.html
