04-18-2015, 06:13 AM
I love being woken up at 2:30 in the morning by one of my door contacts triggering and announcing itself as being open; it has just started doing it repeatedly!
It\'s a heavy duty sensor that supports wider gaps (up to 40mm) but I\'m running it with just a 25mm gap. Its a normally open reed switch so the magnet keeps closed.
I\'ve fired up Comfigurator and can see it triggering on/off in I/O monitor.
I unchecked the \"Announce\" checkbox and did a selective write to Comfort but it still kept announcing; so remind me what does that checkbox do?. I then set the \"On\" response to null and did a selective write and now the sound has stopped.
Sat hear now at 3am watching I/O Monitor; what else could I be doing at this time of the morning?
hock:
I could see it triggering on/off a few times after that but now as I write this it seems to have stopped in the I/O window and I\'m left with just the Flag updates from my UCM/HM every few seconds.
Any ideas; do you think it is the sensor or Comfort wrongly sensing. Surely there\'s not much to go wrong in the sensor apart from the magnet having enough Oomph to keep the contact closed and surely it shouldn\'t loose that over 2-3 years should it?
Confused and \"Sleepless in Newbury\"!
hock:I could see it triggering on/off a few times after that but now as I write this it seems to have stopped in the I/O window and I\'m left with just the Flag updates from my UCM/HM every few seconds.
