I have just re-commissioned my Comfort system, which is running firmware 7.071 with a UCM with firmware 7.061 and ETH 03 running 2.14.
The ETH 03 is set to set the Comfort time via NTP and in Comfigurator I have Comfort set to UTC - Dublin, Edinburgh, Lisbon, London Which is correct since this system is in London.
However I notice that the Comfort time is 1 hour early now that the UK has moved to BST and the clocks went forward one hour.
I don\'t see any more places I can change this, so any help greatly received.
I should add that when I use server manager and look in SNTP settings the local time is correct. GMT Time offset here is set to 0 and Readout also 0
