Threads: 8
Thus anybody know how to add the values of two counters and load ir on a third counter.
My problem is i have a counter temperature and a counter ventilation and i want to add this two counters and the result load on a counter called IRCode.
Threads: 880
There is no direct way to add 2 counters
There may be an indirect way because there is an action to subtract counter from last action value
Get Counter Counter001
Get Negative
Set Counter002
Get Counter Counter003
Subtract Counter002
Set Counter004
This adds counter 3 to counter 1 and saves in counter 4
counter 2 is used to hold the negative value of counter 1
counter 3 - counter 2 should be the same as counter 3 + counter 1
but I am not able to test tihs now
Threads: 62
Chiu, I tested it and it works perfectly.
Threads: 8
Thanks it works perfectly, perhaps next configurator we have this implementation directly.
Threads: 880
Thanks ingo
It is rare for something to work right first time
