Threads: 206
I have noticed that the KP04 back light appears to go out after a timer that appears to be set from the first press of a key?
Can the timer either be increased so the light stays on longer
or (preferably)
The back light goes out after a timed period after the last key is pressed.
Threads: 885
The backlight does go out 10 seconds after the last key is pressed. We are making a change in future firmware that it will remain on as long as the keypad is being used, and will go out only after the lady says goodbye
Threads: 206
Not the case
Back light goes out after what I believe to be a timer on the first key pressed - or certainly aftrer the code has been entered.
What will the change envolve can I uprade customers existing keypads?
Threads: 206
Not the case
