Known Bugs
Bugs Fixed
- For Heatmiser, read from EEPROM is blank but learning works. May be a problem from Comfiguraut 3.7.6
- in KT03, selecting a few buttons and changing some visual attribute may result in exception. But when the exception is cleared, the attribute is changed correctly
- KP06 Screen shows \"Read from Keypad\" and \"write to keypad\" which should not appear. Ignore these buttons
- From Comfigurator 3.9.5. Read from Comfort will cause Functions > Thermostats to fill up the unused Thermostats with sensor 0 and assign Heating and Cooling Outputs to Output 1. You will not be able to control Output 1 after reading from Comfort. In order to free up Output 1, unasssign the outputs from each Thermostat
Bugs Fixed
- For UCM/Zwave, the Virtual Node Info button was missing
- KT03 Button programmed to activate Response did not work - it sent Keypad key command instead
