Threads: 15
When I run the Comfort Server Manager 2.0.6 (CSM) on my 64 bit Windows7 main computer, it will not / can not find my UCM/ETH03. However, if I run the program on my 32 bit Windows7 laptop - same network; same network switch; same subnet etc - it finds it instantly. The ETH03 has a static address and on the 64 bit machine, I can happily read from, or write to the Comfort box using Comfigurator - even though the CSM won\'t find it. I have tried turning the firewall off on the computer, but to no avail. Is there a problem with 64 bit Windows running CSM?
Threads: 15
I don\'t think that port 30303 is being blocked, but what Wireshark is showing me is that the discovery packets are being sent from an address that is NOT my computer! In fact, not even my subnet!
46 3.225923000 192.168.56.1 255.255.255.255 UDP 70 Source port: 30303 Destination port: 30303
and my computer\'s address is 192.168.100.160
I don\'t have any network interfaces within that range at all - so where is the CSM getting that address to send the packets? No surprise it isn\'t seeing ETH03!
Threads: 880
i think wireshark only shows traffic to/from your own computer so your PC network may be set up in a weird way
Try running wireshark from another PC (but dont run cs manager) and see if it can see the same IP address
Threads: 62
I\'m glad you found the problem. The 192.168.56.1 is exactly the same as my VM interface. Just check that the OS doesn\'t prefer that one over the actual physical interface or perhaps a strange static route somewhere. Check the metrics when you do a \'route print\', it should tell you which one is preferred(lowest = better).
Ingo
Threads: 880
Thats good information thanks
