KT03 Firmware 7.064 (Beta)
There are major  changes in this firmware. Please download from https://www.cytech.biz/kt03_firmware.html
However please note that Comfigurator 3.9.9 has a bug that KT03 button cannot activate Responses. Please upgrade to Comfigurator 3.10.3 or later
Known Bugs
  1. KT03 Button trigger Responses does not work for Response number > 999. A workaround is to change the button to Increment Counter. The counter will trigger Counter Response
  2. Output status in a button for Output > 64 will not work
Bugs Fixed
  1. removed 2 extra lines in some icons which should not be there (proble from Domopor installer)
Improvements
  1. Improved firmware upgrade - Allow KT03 to be upgraded successfully when upgrade failed or KT03 reset or switched off and on, unless boot sector is corrupted
New Features
  1. KT03 Button Element added new Comfort Action Types; Increment Counter, Decrement Counter, Output On, Output Off, Output Toggle, Flag On, Flag Off, Flag Toggle. This is in addition to Response and Keypad Key. These new action types allows outputs, Counters and Flags to be directly controlled by KT03 without having to use Responses. The use of Responses is problematic because editing Responses may cause the Response number referenced by KT03 to change, which requires Write to KT03 to synchronise Response numbers between KT03 and Comfort. Comfigurator 3.10.3 is required. see http://www.comfortforums.com/forum90/4216.html
  2. KT03  event log  fixed bugs which only displayed the 1st page of events. Now all events can be scrolled in KT03
Known Bugs for KT03 7.064
Also please note that Comfigurator 3.9.9 has a bug that KT03 button cannot activate Responses. Please upgrade to Comfigurator 3.10.3
