Threads: 20
Hi - I just cant seem to get the external PIR to work
I\'ve connected power to the unit and the \'A\' output from the PIR to the zone, as it says in the manual and have programmed the zone as NO switch but cant get it to work
What am I doing wrong? I\'ve attached the manual for ease
Kind regards,
CG
Opal-XL-Manual-.pdf (Size: 350.71 KB / Downloads: 9)
Threads: 885
01-10-2015, 02:01 PM
(This post was last modified: 01-10-2015, 02:08 PM by slychiu .)
Are you sure that it does not work? Did you do a Security check F,3,2 and test the sensor?
How are the EOL setting for the zone? I suggest to set for NO EOL resistors and do not connect any EOL resistors
If it does not get detected, measure the voltage between the zone and common when there is no motion and when there is motion
the voltage should be 1.2V if no motion and 0V if there is motion (approximately) with NO EOL resistors and shunts accordingly
Threads: 20
Thanks.
Can you confirm the wiring is correct?
Gjd - comfort
12v - 12v
0v - 0v
A - zone input
Nothing in zone common
Thanks as always
Threads: 20
Thanks. Ok, I\'ve now got 2 out of 3 working. There must be a fault with the 3rd unit.
Thanks for helping me resolve this issue.
Kind regards
CG
