Change engineer code does not work for Keypad
How can change engineer code from default to any number
You can press \"F+0+engineer code(default 6789)\" on keypad .Then you will hear the voice menu,after that choose \"Change sign-in code\". It will ask you to key in the new sign in code
[user=5285]CytechMartin[/user] wrote:
Quote:You can press \"F+0+engineer code(default 6789)\" on keypad .Then you will hear the voice menu,after that choose \"Change sign-in code\". It will ask you to key in the new sign in code
Sir I press F+0+engineer code(default 6789) and choose no.6 for Change sign-in code\" but the code change for user not for engineer i mean when press new code for example F0 1981# the keypad say press 0 for security system
and when press F0 6789# the keypad say engineer menu  this mean engineer code not change
Did you sign in the Engineer Menu to change Sign-in code?
You also can go to Comfigurator, Security--->Sign in code, select Engineer,type in new password on right window and click Write User Code
Yes i input to sign in the Engineer Menu to change Sign-in code
in Comfigurator, Security--->Sign in code  the code is change  but i need change by keypad
That looks like a bug. We will check it out and let you know when it is fixed
This was found to be a bug from firmware 6.008
It has been fixed in ULT 7.068 (Beta)
Please download and test
