10-25-2014, 11:47 PM
I had two cases where when opening the garage door, the control panel did a soft reset. The first occurrence the alarm was in day mode (which was a concern as the panel takes a while announcing zones before re-arming).
I looked at the logs and found the following
The same issue was in my older logs
I am using Comfigurator 3.9.2 with Ultra II version 7.061, two slaves (version 6.068)
Code:
10/25 12:10 DSP/Voice Fail 1
10/25 12:10 DSP/Voice Restore 97
10/25 12:10 Reset 97The same issue was in my older logs
Code:
12/03 11:31 DSP/Voice Fail 32
12/03 11:31 DSP/Voice Restore 97
12/03 11:31 Reset 97I am using Comfigurator 3.9.2 with Ultra II version 7.061, two slaves (version 6.068)
