Example: file *.cclx for UCM/KNX
Hi all,I\'m a newcomer and i\'m finding out UCM/KNX, can you give me a program complete for UCM/KNX?Thanks!
A simple example of a cclx file with KNX is attached
Go to Modules Tab and select UCM02 (which is normally the KMX UCM id)
The KNX to Comfort screen is shown
Lighting Group addresses 1/1/1 to 1/1/3 are mapped to Counters 1 to 3 in Comfort. This means that the Lighting group states will be kept in the counter when there is any change. eg 0 for off and 255 for on and 1 to 254 for dim levels. The Comfort Control menu can control the KNX  lights
Keypad Key is mapped to 5/1/0 (1 byte object). This allows a KNX touchscreen to have keypad buttons 0 to 9, Enter to simulate the comfort keypad to disarm the security system using the user actual code.
for example
Panic Button is mapped to 5/1/13 (1 bit). This allows a KNX button to trigger a panic alarm.
Arm to Away, Arm to Night, Arm to Day modes are mapped to 1 bit objects
Time and Date are mapped to KNX Date and Time objects so Comfort time (which can be synchronised to Internet Time server via UCM/ETH03) can send its date and time to KNX.
The Comfort to KNX screen is shown below. This is for Comfort alarm conditions sending to KNX.
Zone Status is mapped to 5/1/1. This maps a range of 1 bit group addresses from 5/1/1 to 5/1/96 corresponding to max 96 zones. if Zone 1 opens, the KNX group 5/1/1 will turn on and vice versa. Allow for as many group addresses as there are zones in the system
Zone Not Ready is a 1 bit group address which turns on when the system is being armed but a zone is open
Armed State is 1 bit meaning that the security system is armed, and is off if not armed
Alarm state is 1 bit which is on if th system is in alarm state
Panic state, Tamper state, Line cut, zone trouble, Low Battery, AC Failure are mapped to 1 bit group addresses which signal the condtion in the system
.zip   knxexample.zip (Size: 18.18 KB / Downloads: 13)
The Control Menu is shown
This allows Comfort to control the KNX Lights by setting the mapped counters to 0 for off and 255 for on
The Counter status gives the feedback status for the mapped group address
This control can be done via the Comfort iOS and Andrroid app
Thanks for your help!
