Hello,
I am experiencing a strange issue with the date and time settings of Comfort:
...so that would mean all is fine, but differs from the output of DT? and the Keypad display. Clicking YES results in the following conversation on the I/O monitor (excerpts only):
[font=\"courier new\"]> DT20140918092207
< OK[/font]
[font=\"courier new\"][...][/font]
[font=\"courier new\"]> RS
< OK
> LI
< LU00
> LI****
< LU01
> LT01
< OK
> DT
< DT2014010508482700
[/font]
[font=\"courier new\"]> DT?
< DT2014010508484200[/font]
Again date and time is not correct. Trying [font=\"courier new\"]Transfer - Set Comfort Date & Time:[/font]
[font=\"courier new\"]> DT20140918095717
< OK
> DT?
< DT2014091809572601
[/font]
[font=\"courier new\"][font=\"verdana\"]This worked.[/font][/font]
Bottomline:
Thanks!
Stefan
- I use Windows 7 in an Oracle Virtualbox environment with Comfigurator 3.8.10.0
- In [font=\"courier new\"]Configuration - Modules and Settings[/font] [font=\"courier new\"]\"UTC+1 Vienna\"[/font] is set as timezone, and the daylight saving (Schedule - ) is set to be active until end of October. UCM-KNX is set to send date and time from Comfort to KNX.
- Comfort was programmed yesterday evening to display the correct date and time using the [font=\"courier new\"]Transfer - Set Date & Time[/font] option
- Sometimes during the night an hour was lost, at 06:15 a.m. the Keypad only displayed 05:15 a.m.
- It is now 09:20 a.m. - I started Comfigurator, and the answer to DT? is:
DT2014010508203700
- [font=\"courier new\"]Transfer - PC-->Comfort[/font] (with the Option [font=\"courier new\"]Set Date & Time[/font] selected)
< OK[/font]
< OK
> LI
< LU00
> LI****
< LU01
> LT01
< OK
> DT
[/font]
< OK
> DT?
[/font]
Bottomline:
- [font=\"courier new\"]Transfer - PC-->Comfort[/font] (with the Option [font=\"courier new\"]Set Date & Time[/font] selected) sets a wrong date (5. Jan 2014) and time (1 hour back).
- [font=\"courier new\"]Transfer - Set Comfort Date & Time[font=\"verdana\"] works[/font][/font]
- [font=\"courier new\"][font=\"verdana\"]During the night, the time somehow was set back 1 hour without any programming
[/font][/font] - [font=\"courier new\"][font=\"verdana\"]Simultaneously or later also the date was set back to January[/font][/font]
Thanks!
Stefan
