IR learning fails with UCM/ETH03
Hi I am building my system and I am testing the IR learning function but I cannot get it to work.
The scenario is as follow: Create a new remote (Hauppauge MCE) and program a new function (Standby)
The UCM connection box is black and stays black but if I roll the mouse over the box I can see the IP address and port.
1.  Press start, after 10 seconds the Busy 1 lights and then  I get the \"No response from UCM\" message.
2. If after Busy 1 lights I press the button on the remote then the signal is seen by the UCM in that Busy 2 lights momentarily then all leds light up (the same as if you press reset button) before going back to the normal function (Green only)
The PC screen doesn\'t change from the \"No response\" message
Can anyone please help?
UCM 7.048 / Comfigurator V3.8.8.0 (EDITED by admin)
Thanks...Pharris14
My apologies..finger trouble.
The Comfigurator is at V3.8.8.0
I\'ve encountered the same problem here on my test bench with the ETH03 firmware v2.06.
Please downgrade the ETH03 firmware to v1.12 for the time being.
It can be downloaded from: https://www.cytech.biz/eth03_firmware.ht...ory_id=101
select the ETH03_general_1.12.zip
Hi Hendy, thanks for the advice, this works fine.
Is there a fix coming for this?
It should be fixed in the next ETH03
IR learning has been fixed in ETH03 firmware 2.09, please see http://www.comfortforums.com/view_topic.php?id=3904&forum_id=113
