DM02 & Farfisa Profilo wiring help?
Hi all. Bought all the necessary components for the external doorstation and I\'m just going through the wiring diagram to understand it prior to fitting... noticing a couple of discrepancies that I hope someone can clear up for me...
In the DM02 manual, on page 9 it shows the connections to the PL11P module... the diagram shows 11 connections, specified as: \"P, C, 4, 3, 2, 1, A, -, H, V, M\" I  see it notes that \"H, V, M\" are for PL41 only, so I don\'t care about those as I don\'t have the video model...
MY PL11P doorstation module has 10 termination points in 2 banks of 5, which are labelled: \"1, 2, 3, 4, L+\" on one bank, and: \"A, -, C, P1, P2\" on the other bank. Also I notice that P2 is the label engraved into the plastic casing, but on the removable terminal block that point is labelled as \".\" (i.e. just a dot). The DM02 manual doesn\'t specify \"P1\" or \"P2\" (aka dot) at all, it only specifies \"P\" - so which do I use? - I am assuming \"P1\" since that is adjacent to the \"C\" terminal, and I see those two are the BELL/GND lines for the pushbutton.. is that correct?
No mention is made of the \"L+\" connector in the DM02 manual. on the datasheet that came with the PL11P, this is listed as \"AC or DC power supply input for service LED (12Vdc-ac)\" - any information on what this is? - do I need it?
Finally the module also has a short captive flylead emerging from one end with one red & one black wire terminating in a wee plug... I\'m assuming this is only for joining to other farfisa button modules? and I guess I don\'t need it at all and can leave it disconnected inside the backbox?
I *think* I understand it pretty much, but I like things to be precise & accurate!! so looking for a sanity check of my assumptions & a little reassurance...
Many thanks
Paul G.
Let me check on the actual PL11 P module against the DM02 manual. I do not recall offhand, although I beleive you have it figured out
Quote:In the DM02 manual, on page 9 it shows the connections to the PL11P module... the diagram shows 11 connections, specified as: \"P, C, 4, 3, 2, 1, A, -, H, V, M\" I see it notes that \"H, V, M\" are for PL41 only, so I don\'t care about those as I don\'t have the video model...
yes please ignore the unused pins
Quote:MY PL11P doorstation module has 10 termination points in 2 banks of 5, which are labelled: \"1, 2, 3, 4, L+\" on one bank, and: \"A, -, C, P1, P2\" on the other bank. Also I notice that P2 is the label engraved into the plastic casing, but on the removable terminal block that point is labelled as \".\" (i.e. just a dot). The DM02 manual doesn\'t specify \"P1\" or \"P2\" (aka dot) at all, it only specifies \"P\" - so which do I use? - I am assuming \"P1\" since that is adjacent to the \"C\" terminal, and I see those two are the BELL/GND lines for the pushbutton.. is that correct?
L+, P2 and . (dot) are not used
Quote:Finally the module also has a short captive flylead emerging from one end with one red & one black wire terminating in a wee plug... I\'m assuming this is only for joining to other farfisa button modules? and I guess I don\'t need it at all and can leave it disconnected inside the backbox?
you mean the red and black wires shown in the picture?
That is not a \"wee plug\", it is  the microphone. It should be mounted in a little slot on the bottom of the housing. It is separated from the main housing which has the speaker to prevent howling
Aha. yes, it\'s the microphone!!
One more query.... how does one remove the plastic cover over the nameplate? (cleanly!)
Cheers
Paul G.
Never mind.... sussed it...
Cool
